chain case drain bolt?
super1c
Super Moderator
Freeland & Otsego lake, MI
Know i know this will make me look stupid after i get the answer but i cannot find the drain plug on my 2002 viper chain case. I know where it should be but i just dont see it. I'm to this step in changing out the track. Also when putting it back together do i need to do anything special to the gasket? Thanks again guys, chris.
Give it a reach around and you'll find a 12mm bolt on the inside of the tunnel. If you look from opposite side you will/should see it.
The chaincase drain bolt is up inside the tunnel, near the drivers. It's either a 10mm or 12mm bolt...can't remember which.
The gasket is just a rubber seal, and are reuseable.
Thinking about doing this on my 03 Viper... do you need to remove anything or can you get at the chaincase as is?
I got at it just fine removing the can. Its till tight as you know. Theirs just know room to work in there. I still love how my 96 vmaxx sides drop down.
