I asked in an earlier post when clutches are worn out, one of the memebers mentioned the clutch faces wearing due to the # of miles on them but did not mention anything about the actual dimensions and wear limits of the clutches. Does anyone have the nominal dimenions of the clutch sheeves and what the maximum amount of wear can be?
Mills
Mills
RJH
I think he would be referring to the face....simply use a straight edge...and look for a valley.
Some clutch faces like the TRA have two angles ..however.
