Ohlins from a 97 sx 600 on a 01 MM?
norwegian
Well-known member
norway
Will the front ohlins from a 97 sx 600 fit a 01 MM 700? What mods might be necessary?
Are you sure they are going to be shorter? The stock mm shocks have 67mm? of travel..
norwegie!!!(ADRIAN) haven't heard anything about your SRX this season.Didn't you even ride it at all since the re-build??Haven't heard you complaining about DCS or anything else.What is the scoop here????
Ohlins
Because of the OE sag on my 01 SXr, the ohlins with the modified 97 SX top brackets and ski stance reduced to 40 inches rides higher in the front then before. I also am using the same ohlin as my centre shock on my long travel Pro Action rear skid and liking the easy adjustability from trail to mountain riding. Rear shock is a Firecat Fox Float
