lowmilevmax
is there an easy adjustment to do on a 96 vmax xt to pull the skis off the ground. the sled is all stock. if not then no big deal
Sledsquatch
- Sep 29, 2008
- Carleton Place, Ontario
- www.simplifiedaudiovideo.com
Car jack.
Have me sit on the back?
lowmilevmax
jackstands?
let the limiter straps all the way out, tighten up the front shock in the skid, loosen the rear shock. play with these adjustments and see what you get. these are no cost. you can play with the spacers on the transfer rods, but thats a little more involved and you would have to buy spacers.
SWEDE
Those spacers can be cut if you wanted to go that way, cutting down the top ones some will give you more transfer.
take the top ones off. lol
If it has the original crappy track from new, studs or a newer, more aggressive track will really help too. A friend of mine had one that just snowploughed through the powery stuff until he changed it out and that helped lift the nose up some at least.
