Well it has been some time since the sleds were started and moved to the storage shed.Since the Flood out here,they have been sitting in my garage collecting dust.Yesturday was a good day to wash,grease and fog them.
My 1976 Artic Cat started in 5 pulls(great),my SX600R started in 9 pulls(not bad) and the famous 2002 SRX started in 19 pulls(what the?)
Ran the SXR down the lawn and couldn't resist a little to give her.Lifted front end a good 3 feet and cat walked her.Then the SRX was even better.Decided to go the opposite way so I could get more of a run with it.Just barely touch the throttle and she was jumping up..love it's power.Turned it around and cranked it a few times.WOW!!!She just shot forward and the ski's went up.Did this about 5 times.Man I sure can't get over the power of the SRX..felt good to pin her again. It is so instant and response is quick.Only problem is I have a few spots in the lawn that the grass has been torn out.Oh well it will grow back.
mulderdad
Last time I had the srx on the front lawn, I told the wife I was just airating it. LOL!
yeah..funny eh.I would call it more like roto-tilling the lawn at my house,right down to the mud...lolllllll
Cam/ Viper adict
You should see my lawn, have none...lol... Could make for great mud bogs at my place...lol...
jasonlmrx
oh yea i like doin that evry once in awhile =) 19 pulls jeez mines always starts in the first 3 pulls... =) wonder why??..
Maybe he "flooded" it...lol. How long was it under water Blue?
it wasn't in the water firstly.Most SRX's are hard to start after sitting for a month.Carbs must go dry or something.I will try the trick of shutting off the shut off valve after a days run,just to see if it will start faster once I turn the valve back on the next time I go riding.That will be my homework next season and I will post on it.
Cam/ Viper adict
Nearing the end of May and you are still playing with the sleds....sweet... I think a shut off valve might be a good solution. Another sugestion, would a fuel pump off a Viper work on the srx? I dont think the fuel can drain back through those pumps. My machine always starts on the first turn of the key and if its sat for a long time maybe 2 key turns...
what about a back valve installed inline on the fuel line..that should work.
Sledsquatch
- Sep 29, 2008
- Carleton Place, Ontario
- www.simplifiedaudiovideo.com
Maybe a primer bulb could help.
a primer bulb could be the answer.I wander if most of them have a check valve built in?
Cam/ Viper adict
I like the check valve idea, more so than a primer. But why do some start easier than others?? There must be something different in the fuel system plumbing on them....
Sledsquatch
- Sep 29, 2008
Can your fuel pump be rebuilt? Maybe it needs new diaphragms? I just think a primer bulb should be installed on anything carburated.
Primer
something like this should work.It is in around $22.00.
Primer kits
This is Made in the USA..
These Kits include Installation instructions..
Eliminates hard starting problems. Replaces the Choke Mechanism and allows you to give your carb the correct amount of starting fuel each time. Comes complete with brass plug, spigot, and T
Primer kits
Then you'll have to paint it yellow......
not yellow..ah.Why???
Doo's came with those style primers for a very long time.....
I'm just yanking your chain though.
