srx help
srx600
I wouldnt count on it:
Most SRX owners THAT HAVE ACTUALLY TRIED DIFFERENT BRAND PIPES will tell you the factory pipes are the best (unless your motor is bored ported etcetc), and the V force may add 1 hp.
I wouldnt race for pink slips, and would contact TURK with further questions, because he had one all set up.
SRX HELP
if set up acorrding to pipe makers specs it should work good,but all your after market pipe aren't insulated or ceramic coated and unless they are really hot wont make the power,for the v-force is that 1 hp on a dino
