Ski help?
PenguinLuke33
Skaneateles
When i bought the snowmobile it had GYTR skis on it and i just bought the deep keel saddless skis. When he put the GYTR skis on it he just put his own bolts on and I don't trust them, what will i need to put the new skis on to make it safe, as in the rubber absorber or the bushings? and also how do i know if I put them on correct?
Deep saddless skis from whom? Check with ski manufacturer by phone, or if OEM, check out cycle parts warehouse, or Babbitt's, - (microfiche) -for online deals. Sponsors may match, don't know... Anyway get proper mounting hardware,, down to nut & bolt.. Need both skies on ground and connected to maneuver around those trees,, stumps, ditches or otherwise terrain.. Be safe & secure. Better times.. for sure...
Look at the parts breakdown on the home page here to see what parts are used. It should be easy enough to figure out how it goes together. A service manual will tell you the torque to use.
