wlcable
I have a 1992 VK540 that is in need of a new track. I have found a used track from a 2004 Skandic WT 156"x20"x1.25" studded. Does anyone know if it will fit on my VK?
bravo-guy
yes it will fit, all wide tracks have the same size track, just different lug heights, and I think 1.25 would fit fine, also replace any bearings that need to be replaced, in the suspension and chain case (or gear box, can't remember whats in the VK, my fathers Skandic has a gear box)
SRXSRULE2
According to Yamaha the older style VK540 that they still make uses a 156x20x1" track so I agree with bravo-guy it should fit. It is a fan cooled engine so there is no heat exchangers that you would have to worry about puncturing so you should be fine.
