I HAVE A 94 YAMAHA VMAX 600 BORED OUT TO A 700 PORTED AND PIPED I HAVE 38MM MIKUNI CARBS WE RUN THIS IN THE SUMMER IN A MINNI ROD WE GROUND THE WEIGHTS TO GET A LITTLE MORE RPM AND NOW WHEN WE GET UP AROUND 8000-8400 RPM IT HAS A MISS ALMOST SOUNDS LIKE A REV LIMITER WHEN WE BACK THE RPMS DOWN TO 76-7800 RPM IT RUNS GREAT. DOES ANYONE KNOW IF THIER ARE REVLIMITERS IN THES IF SO CAN THEY BE REMOVED.
i dont think there is a rev limiter ..they run them rpms in the sled ....sounds like a clutching issue ...i would say thors but you probaly have bypassed it and removed it ...
If there is a rev limiter it will be programmed into the cdi so the only way to get around it would be to reflash that. Probably not going to find a race box for one of those anymore if anyone even made one.
Good luck.
Good luck.
INLINE4
- Jan 6, 2006
Check the ohm resistance on the spark plug caps...4.5-5.5
that may be an issue the pto cyl plug cap was 6.5 and the mag cyl was 13.75 i tried some ngk ones i had lying around but they were both over 12 ohms i will get some new ones tommorrow and see if that helps this weekend
thanks for the help
thanks for the help
