Chaincase ideas.....
valin
Val Caron, Ontario
Hey guys. I am trying to find a chaincase with a longer Center to Center distance. Ours is 7", and I would like to find one that is 8 to 8.5" or so. Yes, I know AVID makes one, but $650 is rediculous. There must be some OEM chaincase that is this long.... any ideas?
The longest I have found is a chaincase from a Pro X, which supposedly is 7.92".
If not, I might just build one out of two.
move the engine forward like they used to do in the old days or run a shorter track would be my guess.
How about dropping the drive shaft to get a better approach angle on the track and also make room for 10 tooth drivers and longer studs..
2ooosrx said:
Is this going on the SRX chassis and if so, what are your plans for having a larger center to center distance? I cant think of any off the top of my head.
Maybe I have alterior motives. A bit more clearance for longer than 1" studs with the 10 tooth drivers is one of them. There is another, but i'm not spilling the beans just yet!
