phazer 485 carb modifications
big-kid
indiana
been reading alot about updating the phazer carbs when installing a AAEN pipe. one post said to remove welch plug and drill midrange hole another said to replace primary nozzle and main nozzle. could the stock nozzles be redrilled or just drill the midrange hole after removing the welch plug. what are you guys thoughts. thanks...
Contact Aaen.
It is not an update on the carbs. It is needed for the right fuel mixture when using the pipe. If you go back to the stock exhaust, the carb will also have to be changed back.
phazer max said:
what jetting install phazer 1992 porting d.g pipe
tmx 38 pilot and main - needle clip thanks
i would start out with the stock needle in the carbs set in middle clip with 45 pilots and 260 mains
