Sled warm up!
Tenderly,, on your two stroke,, use full choke to get started-- click to half- while manipulating throttle to idle as smoothly as possible, depending on temperature this doesn't take long.. turn choke off as soon as you can as u you throttle it also,,= to run smoothly till half rump warmed up,, about 4 min.. then pull from dock ,,putt down river,, = another 4 min. then open it up on frozen lake as soon as possible....
Start it and let it sit until you have good heat in both running board heat exchangers. Every sled is different. My wife's 700 redhead heats up twice as fast as my srx.
I've got one on my srx. It goes to 107F, the stat opens and it drops to about 95 or so and starts to circulate and heat the exchangers, then when it gets to about 107 or so it's good to go.
norwegian said:
How about getting a temp gauge?
