I seem to be having troubles installing them. Looks like the right hand pipe goes over too far or sits too high or something. It rubs on the inside of the panel. If anyone has the instructions to do this or has done it before and can tell me how, please, I would REALLY appreciate it. Thanks.
Kevin-MI
Did you remove the original pipe bracket? If not the PTO side pipe won't sit low enough.
thanks man. will that make enough room for the mag side pipe to clear the panel?
I remember seeing instructions to cut down the mount for the pipe, so that the spring can be utilized to hold the pipes from bouncing around. T
no1chevyboy
with the kit there is a new bracket that must be bolted in after you cut 1/3/16 or 30mm but if you dont have bracket ,after you cut 30 mm from where the muffler rests you can cut the rest with spring holes from the piece you cut off and weld it back on or order the bracket GYT-8bv93-25-11 you also need Q-8 needle jet 8AY-14141-58-00 and 4 needle shims 8AB-14227-00-00
Kevin-MI
6.0l zr2 said:thanks man. will that make enough room for the mag side pipe to clear the panel?
I meant the the mag side, sorry.
