98 msrx powervalve adjustment
myamaha
saskatchewan
On the srx there's a caped plug with three wires. Can I use a 12 volt and jumper wires or does it need a resitor in the line. Which wire is the positive or is one red wire positive and one red wire negative or is the black still negative and one red wire positive. I heard you can maybe burn out the cdi box if not done right.
