Clutch set-up **Turk or others Please help**
speedracer
01 SXR only mod done is reed notch and 142.5 mains. Mostly ride 2000Ft or less. I have a 50/44 Advantage helix and would like to use it if possible. Could someone please give me a good all around set-up with more emphasis on good backshift. If I need to buy other helix, weights, rollers, etc. so be it, I just don't want to waste my $$ on another "clutch kit". Thanks in advance.
The 50/44 advant-edge is gonna be pretty steep for your sled. The stock weights & rollers will backshift very well. I have a 52/44 Bender helix that I would be willing to swap for your advant-edge. The Bender cut is not nearly as aggressive & will backshift & work well with your present set up. You can PM me if you are interested.
