distances
gmcdunnah
Northern Maine
would anyone know the center to center distances for all the radius rods and all 3 of the steering rods to save me some time?
assuming your on the srx in your avatar, heres the info i have: rad rods w/o ball joints: upper-424.2mm, lower-417.7mm. rods with ball joint: left and right upper-460.2mm, lower-458.7. tie rods-504.6. the other steering components you will have to adjust on the sled. these are from my 98 srx.
gmcdunnah said:
wouldnt happen to know that in inches would ya?
Trust me when I say this get yourself a metric tape or ruler and do your measurements with that,it will be far easier to make exact adjustments with metric rather than imperial.I know that metric may not be what your used to but it is simpler and easier for this kind of measurement.
This conversion chart should give you the imperial measure you need if you want to go that route 1 mm = 0.03937 in,take the number in mm and multiply it by 0.03937.
