Anyone know? Id like to know where the peak hp is made w/ the GYT Twins so i can clutch accordingly. Thanks
mbarryracing
- Aug 30, 2007
- Springville, NY
- www.fullpowerperformance.com
6.0l zr2 said:Anyone know? Id like to know where the peak hp is made w/ the GYT Twins so i can clutch accordingly. Thanks
Call Justin at Full Power Performance. He built and tuned my 600 with GYT's and is a wealth of knowledge on the twins, triples, and the VMAX 4's. He'll guide you right were you need to be for clutching...
FPP
716-699-6299
thanks a bunch man. will do
SamuelJackson
Check this, vmax 600 twinpipe shootout results.
http://www.totallyamaha.net/forums/showthread.php?t=38716&page=1&pp=10
mbarryracing
- Aug 30, 2007
- Springville, NY
That shootout doesn't have the GYT twins, only the single...
YAMMIEGOD3:16
THEY ADDED ALOT OF HP. I BELIEVE JIM AT DYNO-TECH TESTED THESE BACK IN THE AMERICAN SNOWMOBILER SHOOTOUT DAYS AND HP WAS AROUND 110. BE CAREFUL WHAT FUEL AND JETTING YOUR USEING. THE WEIGHTS IN THAT SLED WILL WORK BEST . THESE ARE THE BABY 8BU WEIGHTS WHICH ARE 8CA. YOU WILL NEED TO ADD WEIGHT TO THEM THOUGH. ALSO YOU WILL NEED A DEFFERENT HELIX. I WOULD USE THE STOCK 700 SRX SPRING FOR PRIMARY (Y-W-Y). 3:16 (yammie tony)
what should i run in the secondary tony?
YAMMIEGOD3:16
YOU NEED YPZ HELIX. ANY OF THE MULTI ANGLE WILL WORK NICE. I WOULD SUGGEST A 45-39. SET IT IN NEXT LOCATION ABOVE STOCK. LAST I KNEW HAUCK STILL HAD THESE. RUN STOCK SPRING IF ITS PINK. IF NOT, YOU WILL NEED PINK SPRING. SAME SPRING THATS IN A EXCITER SX. 3:16 (yammie tony)
