Bigger Carbs
lords88
Moscow & Arco Idaho
I am going with a bigger set of carbs for my 944. I am putting on a set of 40mm mikuni flats on. What do I need to do about the throttle position sensor. Also has anyone put a set of these carbs on there sled? Wonder about what needle to use, these carbs came of off a polaris 700 XCR mod I had.
Just unplug the TPS sensor, and ignore the flashing water temp light. It won't affect anything. I've never run those 40's, so I couldn't tell you if the needle is the proper one or not, but I would start with it in the mid position and do some testing.
