Best/Worst Aftermarket Reeds/Cages 4 SRX
Netefrog
ON, CA
What do you guys think about the Aftermarket reeds available for the SRX??? Boyesen, V-Force, CarbonTech, what are you running???
If your engine is stock you can't really improve on the stock reeds, but if you are planning on doing some mods like porting, head work, air box mods than the V-force are a great compliment.
Money would be best put towards clutching if you plan on running stock IMO.
That's where I'm at now, stock motor with clutching and studs. I'm just trying to make up my mind what to do next.
:yam: :2strokes:
Save your money and keep the stock reeds. If you are looking for more performance, have your cylinders trail ported. It will be money well spent.
Where in Ontario are you?
Give Gerry or Flavio Iantomasi a call at (905) 263-4868. They'll fix you up with any motor work you need.
I'm about halfway between Toronto and Sudbury.
And thanks for the connect, I might give them a call.
:yam: :2strokes:
