I want to have a little more comfort when I'm blasting down the trail standing up, so I've decided to install a riser kit on my sled. My questions to you guys are: what brand would you suggest (Rox or Power Madd), and what height do you think would work for a guy thats stands 6'1"???
i had 5 inch fly risers on my srx and i am 6'6 they worked great
Personally I would suggest the Rox but that's only because I have never used the Powermadd and as far as height I don't think you would want anything lower than a 3 mabey even a 4" as I have a 2" plus a 3/4 spacer in mine now and I'm only 6'.
Another thing you will have to consider is longer cables for your throttle and oil pump as well as a longer brake hose to compensate for the added rise.
fourbarrel said:Another thing you will have to consider is longer cables for your throttle and oil pump as well as a longer brake hose to compensate for the added rise.
Will I need extensions for a 3" riser???
I take it your putting this on an 01 SRX?If so you may be OK with just a 3" rise but on my 98 I had to put longer ones on.Buy it and check you wont be disappointed with it either way it's huge improvement in comfort.
yamaha4evr
i have 6 inch powermadd risers with the pivot adapter and love em..im 6' 1"
mcmarkrazz
i got a nice riser off of ebay that didnt need any cables lenghtened and easy install.the guy always has them for sale just do a search they are worth the money and make for a great ride
