Changing Carb Jets SRX
timl1978
Ballston Spa, NY
I need help. I believe I found where the main jets are but where are the Pilot Jets and Needle? These carbs were set for a big bore and now I am going back to the stock configuration. Any help would be appreciated.
Hey tim, yeah ya got the main jet right, the pilot jet is the jet just to the right of the main jet in your pic,down that little tube, youll need a fairly skinny flatblade screwdriver to get the pilot out. The needle jet is accessed from the top of the carb,take off the cover on the top, i believe there is a writeup in the tech section somewhere. Good Luck. By the way this is Ron.i bought the big bore from you,now that you are into the carbs can ya get me the jet sizes and needle position once you get it all figured out. thanks
P.S Pay attention to the position of the two little white washers when you take the needle jet out above or below the clip,and also the position of the clip it self,which groove from the top. Thanks
