I need a pict of some stud setups for 144 down the middle for my Viper
Thanks in advance for your replys.
Troy
Troy
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
http://www.totallyamaha.com/snowmobiles/aaTECH/Stud Patterns/Stud Patterns.htm
These are in the tech pages of this site, you can also look at some patterns on woody's and studboys website.
n2oiroc
i am doing 144 down the middle of my ripsaw, 48 singles and 48 double angled backers. ill post pics when im done.
I think I know what studs I am going with and what backers. I am going with the New Woody's stainless steel studs with Fastrac polymer backers. I am thinking about just going with the single backers. Does it matter if I don't go with the the double backers. I am still undecided on stud setup. I read some where that if I put all the studs in the center belt that it will affect cornering. I also read you should not put studs right in he middle of tha track. Can anyone shed some light on this. Does everyone run their studs in the center belt ? Should I go more then 144 studS ?
sxviper32
2000SRX how did those aluminum scoops work for you? What size lugs did you run with them and how much were they sticking out? I bought 24 of them to test out on a torn up track to see how they did and if i wanted more, but haven't had snow to test them. Any pros or cons? thanks
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
I do not run those, I got those patterns from the tech page of the site. Sorry for the confusion
sxviper32
anybody run the triple point scoops?
