Paint Codes
Not very easily found.
The best thing to do is to go to an automotive paint supply store (Finishmaster, CarQuest etc.) and have them take a reading of the color in question. They should have a color spectrometer to read a color sample (hood, etc). They will then be able to convert the reading into a color formula. I would have them mix it in basecoat (preferable PPG DBC) and topcoat it with PPG clear (DC3000). PPG seems to be the best bang for the buck as compared to the other paints (dupont,basf, etc).
Taken from the "tech section"
Sikkens Brand Blue Metallic with Pearl clearcoat code # 622 D5
Trailing arm silver:
Navistar silver pearl met.
Dupont m1930k alt. 0
Ohlins shocks yellow is Dupont 218a alternate 1
Yamaha Blue Pearl, ...this is an official Yamaha color on PPG color charts, although you can take the following recipe to any auto paint supply outlet. By: srx_eh
PPG MIX @1/2 PINT:
DMD624 58.2
DMD675 100.7
PRL92 123.9
PRL90 132.7
DBX1689 267.3
I bought both colors for $10 at Murray's Auto located in lower Michigan. Make sure you shake the color before using. Both colors are real close. By: viper7mi
Dupli-Color - manufacture
blue - HA 00980 Electron Blue Pearl B95-P Honda
silver - 77-00974 Starlight Silver (M) Clear coat 2001
The new Dupli-Colors come in a cool scratch and fix 2 in 1 pen type dispenser on top with a brush inside. The pen part fills in small spots great.
