Just curious what everyone has tried as far are your front and rear spring settings. Mine is set ot 0 pre-load but had heard that I should crank down on the spring a little. Does this make it drive much softer? WIll this make the hyfax wear faster?
I ran my srx with zero on the front....and the limiters pulled up to keep the skid as flat with the skis as possible...sled rode great. More spring and longer straps will make it wheely and could wear the hyfax quicker...
blue magnaman
mr sled...as allways....is correct.....set yure sled up on a flat surface and try to get it level.....if it rides too stiff adjust the fra.
