calling the clutch masters
staggs65
Sabattus, Maine, United States
got an aaens roller secondary, it has a 52/48 helix with an all brown spring (aaen spring?) what will this helix do compared to the dalton 54/46 i was running in my yammie secondary, i run heavy hitter weights and will reload accordingly, just looking for the helix differences
its going to shift out a little faster....due to the roller. the brown spring is a aaen spring. i can get you the rates and specs on it tonight, when i get home. you'll most likely end up liking that aaen roller, more than the button.
aaen brown polaris driven spring....part #AAS12416....torsional rate LBS/REV=428.....compression rate LBS/IN=65.....also, 1" taller than the AAEN green spring for more side pressure. you could also try the arctic cat yellow spring. i find that it works well. that's what i'm currently using in my hi-tech.
