I hate to ask this!
meat12
Central WI
Yep another track/stud Q. I have searched till my brain was smoking and still cant make a comfortable decision. I believe I have a 1.25 Camo track on my 01srx. Not sure, its pretty beat up and was on there when I bought it. Found some used Woody's studs. Dont want to put new in as the track will be replaced probably next year. Anyway
Stock protectors, driver
1.25 Camo track
Will a 1.25(Overall) Woody's stud fit without causing a problem?
Not concerned about under penetration, as the track is worn pretty badly, just damage to the exchangers because they are to long.
Sorry to ask this again
Meat :dunno:
not sure but i think its to long it will hit the front heat exchanger...watch for the green liquid behind u lolll :letitsnow
FRIEND OF MINE HAS A 1.25 ON A 2001 SRX. SLED HOOKS UP LIKE A ROCKET ON SNOW. UNSTUDUDED YOU HAVE TO REMOVE THOSE PROTECTORS TO GET IT TO CLEAR. HE STUDED HIS WITH A 1.175 MEGA BITE AND HAD TO SHAVE BACK KNOPS TO REINSTALL HIS PROTECTORS. ANYWAY YOU LOOK AT YOUR CLOSE WITH STUDS. I CAN TELL YA ITS NO FUN POKEING THAT EXCHANGER. EVERYTHING HAS TO COME APART TO REPAIR IT AND THE ONLY WAY TO DO THAT IS TO FIND A GOOD WELDER. THAT SLED WILL HOOK LIKE A BULLIT WITH THAT TRACK ON SNOW UNSTUDED, SO I GUESS ITS WORK EITHER WAY. NOW I MIGHT BE WRONG BUT I AM ALMOST SHURE THATS WHAT HE DID 3:16 (yammie tony)
