I have a 03 v max 600 er that fouls plugs on start up. If i change the plugs after started it runs fine. Any suggestions?
Just want to make sure you are not touching the flipper untill its warm. Should fire right up on the enrichener and you should be able to turn off the enrichener pretty quickly then let it warm up.
Could be a worn reed. Are the carbs clean?
I plan to pull the carbs and clean them for this season. Thanks for the advice.
have you tried ngk br9eix plugs in it? solved my brothers fouling problem on his viper.
is it hard on oil? might be oil pump has failed.
