Clutch swap
gun lover
Sault Ste Marie
hi all.
I damaged my primary clutch on my 96 Vmax 600 XT .
can I put a primary off a 2002 phazer on it .
if it does is it just bolt on and go or do you need anything different .
can i use the weights and rollers out of my clutch.
clutch will be the same, except for arms, cover, and perhaps rollers. that newer clutch should have the taller cover. use your short cover uless you want to invest prings as well.
