2002 V-max 600 Over Revving
ACE
ONTARIO CANADA
This Sled Has Done This Since New. It Will Rev As High As 8800-9000 Rpm. Is This Normal And If Not Has Anyone Had This Problem Before.
Yea Tom is right, loading up those stock weights probably still won't get you down to the correct rpm, so to get the best performance you will need a different weight, such as the 8AB or 8CA (same profile, different empty weight), and tune from there.
