Steven DeMarco
- Feb 16, 2004
viper problems aftre engine rebuild UPDATED 9/24
my buddy lost all the antifreeze and blew the motor on my 2002 viper.
I checked everything out and rebuilt the motor. new pistons rings gaskets. was able to salvage everything else. started the engine after the rebuild. Bled and adjusted the oil pump,bled the cooling system and had it running and ideling great. probably ran it for 20-30 mins 2-3 different times. stabilized the fuel and put it away for the summer, 2-3 months sitting in the trailer.
pulled it out this weekend to move some stuff around and it wont run right.
Once it is started it will only run with the choke half way on. take the choke off and it bogs/backfires and tries to die. i am noticing what appears to be oil on the plugs and it seems to be dumping oil into the exhaust also. lots and lots of smoke when it is running.
Anyone got any ideas or seen and issue like this?
any input would be appreciated.
