cacsrx1
I put viper shocks in my SRX skid. Now Im trying to get the skid slid inside the track and it is tighter than heck. Looked at everything a million times and cant figure out what Im doing wrong. Track tensioner is loose etc, what am I doing wrong???
jwiedmayer
Tech Section
There is a proaction install in the tech page off the main page. Did you change the limiter straps also? And what about the control rods? I have not done this mod but I thought you needed to change the control rods, and limiter straps to take advantage of the longer shock travel.. Someone will defintely know the answer.. J
yamaholic22
put the front of the skid in first, up under the front of the tunnel. Then try and pull all the track slack to the back of the sled, lol, and then wiggle the back of the suspension in there. Takes a little bit of jockeying but it'll go.
