sxviper32
I recently purchased 3 TMX 38mm's for my 2001 SRX and came to a problem when I met up with the TPS (throttle position system). Does anyone know what to do or how to bypass it? PLEASE HELP, EXPENSIVE LITTLE SUCKERS!!!
			psi sells a tps block, you bolt your tps on it and it pulls off the throttle cable, this way you keep the 3d timing curve
			sxviper32
Do you know if I need one for each one or will one take care of all of them? Thanks for the feedback.
			1 is for all 3, just like stock.
