OnDaTrail
When you look at tracks, some are fully clipped and some are clipped every 3rd window. I've seen where some say that the fully clipped gives better cooling because more windows are open to let snow through to the slides and I suppose also to the heat exchangers? Is it true, or are there other reasons to choose one over the other. Is the cheaper track sufficient for some riders and not others?
snowdad4
alot of options here to answer your questions. in my experience, tracks with all open windows seem to not wear out the hyfax as quickly. as for the open every third configuration, seems as though track clips weigh more than the rubber square would, so weight savings is the issue here. i remember in the 90's when the polaris rmk came out with the open every third configuration and they were burning hyfax to beat hell. thats where the slp slide buttons came into play. dont know if your familiar with these, but that was the answer to aid in saving the hyfax. i, for one, prefer an all open window track. clip configuration doesnt matter. if i install an open every third, i punch the others open and dont clip. but, keep in mind that we are deep snow riders, not hardpack trail riders, so my experience may differ from yours. we run alot less bogiesthan trail sleds, and use ice scrathers when we have to ride hardpack. hope thhis helps a little. i could go on if you need more info.
Thumper1
seems like a lot of the OEM are going back to open windows
no1chevyboy
a few years ago i had a sled that i put a every third open on, and had no problems! when i was looking, the dealer told me not having the full clip would hold more snow in the track
