How hard to change
jason
Eagle River,WI
I have a 98SRX 700 that I long tracked and got set up the way I want for the most part but would like a dual beam head light on it. How hard/is it realistic to chnage to the dual beam head light?
big job cause its not the same electrical system..u can't run the dual headlamp with stator from 98-99
The stator output varies greatly, I think the dual headlight SRX have a 200 or 300 watt system, the 98-99. have half that. It can be done a couple different ways but it is not easy. You can run the dual headlight and only one bulb...But that is less than ideal.
Thanks for the input. Guess I'm not going to go down that road. Maybe I'll have to pick up a 01 and buid another this time maybe with a 144 tip up.
780srxgeorge said:
hay jason did it work?
Haven't got the headlight assembly in yet. My wrench is working on getting me one from a buddies wrecked sled. When you said not to go over 35w ea how does that work for the high beams then? Also with the dual lights giving a total of 70w is it much brighter than a hyper white bulb single? Thanks.
the 35w-35w has a hi & low.stock is 55w 4 low 60 hi.my yamy buddy has 98 switch 2 this two yaers ago & loves it.the stock lens has a lite fog thay SUCK.this is brit at night at low beam.hit hi beam see 4 miles.the twin light pod diffrent windshield.its going to LOOK HOT!
jason said:
What size are the high beams? Can you get those 35w bulbs you have in a hyper white/sylvania type bulb color?
no. but u can get this things to go over bulb. thay r adaptor cap in jr graham book.in blue or red :bling:
780srxgeorge said:
i got 99 700 with dual lights.i used two 35w-35w.about 15.buck a bulb.works GREATT
Where did you get the bulbs and what brand are they? I have a dual light on my 99 and I would like to run 2 bulbs. I haven't been able to find 35W only 55-60.
The 35w bulbs were the stock bulbs on the Yamaha FZ600s motorcycle 1986-1988. You may have to get them from Yamaha...I know thats where I had to get them for our FZ660 BB. Another suggestion would be to run the 55-60s and cut the low beam prong off one bulb + the high beam prong off on the other so only one bulb works at a time[ie: left bulb for low beam - right bulb for high]...I have done this on most of my twin headlight bikes as well as my 2002 SRX to keep the charging system demand low.
JM.02c
hay guys ther is a motorcycle outlet 6 blocks from house.thay have from harley 2 snow stuff.thats were i got the 35w-35w :hide: :yrules:
I was looking at the yamaha fiche for the FZ600 and the headlights are 35 W but it doesn't say if they are the H4 style bulb. Are they H4 or something else. Thanks
