enclosed trailer roof sealer?
01 msrx
holland MI
the roof is starting to leak on my enclosed trailer around the jionts and were the screws go through, does anyone know of a sealer i can install on the whole roof to keep it from leaking, someone told be you can use roof tar!! will that work or is there a better idea?
If your referring to a Cargo type trailer, the above post is correct. You can use any Elastomeric coating. Stay with white or aluminum colors as black can increase the internal temp quite a bit. Use a 1.25 inch roller cover to apply. Elastomerics are to be applied at 30 mils drying down to 10 mils or so, while your house hold paints are applied at 4 mils drying down to 1-3 mils depending on quality.
Prep is going to be key. Get that surface extremely clean prior to application.
YS
