avasdaddy
how do i know if my straight is aligned and if not how do i fix the problem?
in a nutshell, measure the distance from edge of track to rear axle bogie. tighten the adjustment bolt to the side you want the track to go. keep in mind your track tension, and dont forget to loosen the axle first. in between tightening and loosening adjuster bolts, spin the track manually or using the motor.
