2003 viper 136 long track kit need help
revegadex6
michigan
I put a hartman 136 rail extention kit in with 1.5 track know the back of the track does not touch the ground. what do I need to ajust.
In the rear skid, front shock spring may need to be tightened and the rear shock spring loosened. Or you could pull the limiter straps in the front of the skid up before you try the shock springs, that may be enough. I just wouldn't make huge adjustments at a time, so that you have an idea of how far you have things adjusted. Hope this gives you some ideas.
