reduce throttle pull
mtnviper02
Wasilla, Alaska
I have a 01 MM and the throttle pull is really stiff. I have narrowed it to the rod assembly that connects the three carbs. I disconnected my throttle cable on this sled and my '03 viper to compare. The viper is smooth and returns to idle quickly. The MM is stiff almost like there is some binding or sticking, it returns to idle but not nearly as smooth. Is there adjustment on the spring or areas that require lube? If so what do you recommend. Thanks for your help!
