I have a mint 93 ovation for my son.
Today, I took out the suspension to give it a once over and grease up the cross shafts.
I noticed the shock at the rear scissior is leaking pretty bad.
I have went online to search the part # 85L-47480-00
But locally I can only get the front shock and want to maybe go to a gas unit.
What other machines have a cross?
I am not very familiar with the Yamaha units any help would be great.
Thanks in advance.
Thanks in advance.
PZ 1
- Mar 12, 2005
Are you saying that the shock is no longer available from Yamaha? If so check with aftermarket parts distributors - Dennis Kirk etc.
No I am not saying that yamaha doesn't have the shock..
I am just wondering if there is a cross that might be cheaper than the $160cdn that yamaha wants for a $30 oil filled unit.
If there is a cross, maybe from an enticer or phazer I will be able to get him set up.
they want gold for that stuff. the rear is usually gas charged. went through this 15 years ago for a 78 et250 and i ended up with a kimpex rear for around 1/2 the price of the dealer. any of the old suspenions with the same travel/spring combo should work for you.
Maim,
That is what I was thinking.. Maybe a shock from a later excell 3 unit...
That is basically what the ovation replaced.
