Smart Carb & Oil pump setup
tripplec
Belleville, ON. CA
First does anyone have detailed blow up of these and setup info with the loacation of the various screws. Since I got this sled used I have confirmed even though it runs well it not performing as well as it should top end power and speed is lacking and always has. It does use quite a bit of oil.
I got a slightly used oil pump from a member two years back and only just found the info and now see the mark on the casing for the full trottle setting. Which if I under stood the info is the only setting. Nothing for low trottle point. Is changing it straight forward? Mounting and reconnecting the two oil lines or does the air need to but worked out as well somehow. I read a few years ago tha some members leaned out their thirsty pumps to get an average 50:1 gas to oil useage using old school calculations.
