Thanks for the fast reply Turk.
I think they are from the 08/09.
I'll double check.
Does one work and not the other?
I'm trying to swap mounts with someone on a set of used Simmons skis.
Thanks!
I'll double check.
Thanks!
08/09 uses the narrow mount shared with the new phazer. They are the only 2 sleds that use that mounting system.
Turk said:08/09 uses the narrow mount shared with the new phazer. They are the only 2 sleds that use that mounting system.
Ah got it, thanks Boss!!
Does anyone have a Viper Ski handy that they could measure the saddle dimensions or know them off the top of their head?
I'm out of town, and don't have access to one.
The simmons mounts i'm looking at measure 4" inside measurement and 4-1/2" outer.
Thanks!
Thanks!
mdbauer62
mdbauer62 said:The Viper spindles are 3" wide. See photo....
Thank you very much sir!!
Looks like the doo mounts that are already on there "should" work then!!
They also measure 3" across I.D.
I may have to re-use the stock Yammi rubber piece if the doo is too different...
Thanks again!
