trackusa extension track package
jasonlmrx
Ontario,Canada
hi, ive been eye-balling this nice package from TracksUSA its #7
7 9800C Intense 1.5 x 15 x 136 $659
Or
9108C Intense 1.5 x 15 x 136 $699
Includes 121-136 Rail Extensions and Tunnel Extension with all hardware
9108 has shorter guide clip for '07 & newer Arctic Cat's w/ Diamond Drive
and i was wondering if anyone had ever purchased this track and i used my search button that i love so much to find out that 1.5" lugs should fit on my stock sled.. just wondering if anyone could check it out and give me feedback i think the track extension package would be nice for lots of trail riding and mild soft snow riding..
http://tracksusa.com/extension_packages.html
Thanks Jason.
used to run 1.5" camoplast on my srx - it will fit, but I had to remove the front heat exchanger protectors - about 1/4" of clearance. I actually now run a 2" but changed to from stock 9T to 8T extrovert drivers (smaller diameter)
k thanks i decided to go ahead and order it :)
hopefully it will be here soon so i can swap it on and get it perfectly ready for winter
also ordered a heel cliker clutch kit and will gear it down probably..
Thanks Jason
You will enjoy both the longer track and the taller lug. For trail use the 1.5 is tall enough. You will need to take out the tunnel protectors as well as the cooler protectors as mentioned. XC
