Rx-1 Mountain skid on a MM700?
Detroit Sledder
Thinking about adapting a 2003 RX-1 151 skid to my 2000 Mountain Max and wondered if anyone has attempted something like this. Any pro or con opinions are welcome as I will be going into this blind.
Thanks!
I have done a 121 rx in a 97sx, only had to switch the rear cross shaft to make it work, but if I remember correct you will have to re-locate the rear and center mounts on the mm as the RX mtn has more distance between the mount points
