2000 & up Stator in a 98 SRX 700
madpat
Laona, Wisconsin
If i want to upgrade from a 98 stator to the 2000 -2002 what would all have to be changed?flywheel,pick up coil?wiring harness?is it worth it?could i use the 98 headlight with the 2000 stator?or would i have to change the headlight also.Thanks
all wiring ,cdi ect ,guage are not the same ,thumb heater and hand grip are not the same ,u need to modify the motor case to put the new pick up coil cause the flywheel is smaller , ect ect ..been there done that
When its all said & done is it worth all trouble?I wonder couldn't you take a 98 stator & have the higher watt coils put in the stator(by a stator repair shop?)
Anyone have pics on the pickup coil, how it is repositioned?
Is it in the same place only closer due to the smaller flywheel?
