got a good deal on a track, want to make sure it will fit.
02sxviper419
oregon,ohio
I got a good deal on a used track only 300 miles on it, just want to make sure it will fit. It is a camoplast ripsaw 121x15x1.125 , with 126 woodys studs 5/16x 1.325. i just want to make sure it will fit before i buy it. Will i have to make any modifications to it?
Just make sure the track is 2.52 pitch. Ripsaw # 9921 and 9968 are the 121x15x1.25 versions of Ripsaw that come with 2.52 pitch. The number should be on the track somewhere.
If it is a Ripsaw that came off a Doo it will be a 9048, 9148, 9049, or 9149. These tracks will have 2.86 pitch, which you could use but you would have to change out your track drivers/cogs to match. Those tracks are also 120", 1 inch shorter. Maybe someone else can comment if they would even fit?
--Steve (O.C.)
If you find it is the right pitch, you'll need 8 tooth drivers to keep the studs out of the front exchanger. I had to do that to my 02 when I extended to 136 with a studded ripsaw.
the track is off a 08 800 rev. it has a 2.86 pitch. but he said he thought it was 121, but thinks it is 120. now i don't know if it will fit.
