Maine SXViper
Hi, do i need to pinch the main gas line when removing carbs, so won't drain tank? Thanks!
valin
No, you should not have to.
timl1978
I didn't...
kirk700 srx
You might want to pinch off the coolant lines for your heated carbs That can get pretty messy! use a rag, so you dont tear up hose and some vice grips
YAMAHIZAL700
or find a bolt to fit in it to plug it.kirk700 srx said:You might want to pinch off the coolant lines for your heated carbs That can get pretty messy! use a rag, so you dont tear up hose and some vice grips
sgauthier
for the coolant line i use a center punch, works great because it is tapered. fits in nice and snug.
We use golf tees for the short time we have the carbs off.
super1c
Super Moderator
X2. Always worked greak. Just dont use the painted ones. I did that once (only once). Nothing like cleaning out paint particals you didnt notice till they pluged the mains. Oh well, lesson learned.SXlover said:We use golf tees for the short time we have the carbs off.
