SLP Can Pics (temp)
YamerDown
Ottawa
Needed to share these with another menber and this was the easiest way. I will delete them next week...
Forgot to make comments...
First pic, note the spacers placed on the chain case tab to lift the can slightly. Used a nut as a spacer approx 1". Also note the "cut rubber" used for vibration insulation.
Pic2, bracket on left is missing the rubber mentioned by SLP, bracket on right still has OEM one in place.
I think you should just leave these pics on here, as they may help someone else....(me when I get to putting my pipes on).
