03 Viper 700 Stock Transfer Rods
Cwagner100
NY
I was wondering what the procedure is to adjust the stock transfer rods on the suspension. I want to set it up for better acceleration. Actually I don't even know how they work. Any information would help!!!!!!
The further you move the transfer rod nuts up towards the seat the more your traction is transfered to the ground, therefore lifting ski's. the closer the jam nuts are towards the rear idler wheels, the more your ski's will stay planted on the ground The limiter strap up front can have alot to do with the transfer also the looser you run the straps the further the front of the track will drop So with saying if your looking to dangle ski's jam nuts all the way to the top and limiter strap loosened up. If your looking to keep ski's on the snow, jam nuts towards the rear idler wheels Can anyone else correct me if I am wrong? Or add something I have missed ?
