stock srx 700 500ft time????
j2hizzo
southern maine
Now that I have found a secondary problem, I want to know what I should shoot for when I get it fixed. I was thinking that with me on it(245lbs) I should be hitting around 6seconds in the 500ft.....anyone know what the stock times are for the srx?
if set up for stoc class at 245lbs you should be able to run a 5.7flat flat at race weight 5.5's
The top sleds run those times. a trail stock with 144 studs & stock gearing will be about 6.2ish.
i had somone service my secondary and when they put things back together, they put it on the weekest setting. When i checked it out, I could pull apart the secondary with my hands easily....I adjusted the spring and turned it 60 degrees and its helped alot
THESE SECONDARYS ARE VERY EASY TO SET UP PROPLEY FOR YOUR SLED. IF I WERE YOU, I WOULD LEARN HOW TO DO IT YOURSELF. DUDE, SOUNDS LIKE YOUR SRX IS ALL OVER THE BOARD HERE. 5.8 / 6.0 WILL WIN YA ALOT OF RACES AT BACKYARD EVENTS. 3:16 (yammie tony)
