stealther27
Hey guys this past wknd I became a proud owner of a mint 02 srx 700 and having since owned a 98 srx 700 that was clutched an picked I have been looking through the tech sections in here to see what people have been doing towards clutching with these sleds. Would you guys prefer using the heel clicker or just the genuine yamaha stuff which I have had great luck with?
valin
You can achieve excellent results with both. I run Heavy hitters, myself, or OEM weights.
I run "Heavy Hitters" or "Thunder Shift" weights as I like the ease of adjustments. I do use the Yamaha OEM springs in my primaries.
staggs65
heavy hitters here for the easy adjustment too, you can get good results with the yammie weights just more work to make a change
kirk700 srx
I went with Turks suggestions for my 98 srx adding 8DN 20's loaded up 5.5 gram each hole and my rpm are runnin around the 8500 We still have little to no snow so backyard clutching is almost like keyboard clutching!
stealther27
does anyone have this link for turks clutching so I can get a few setups? thanks
staggs65
top of the page blue bar, ty tech, go to snowmobile tech, from there clutching section, you'll find it
